mpm8789
Member Since 23 Oct 2012
Offline Last Active Mar 31 2015 02:04 PM
In Topic: Frigidaire affinty washer lafw7000lw0
11 October 2014 - 10:47 AM
Ok I'll replace the motor thanks. I figured the resistance was close enough but now I know
In Topic: duet dryer not heat ggw9250pw1
11 September 2014 - 12:00 PM
Yes it did match
09 September 2014 - 03:16 PM
Ok so I installed the board and nothing not heat at all. I put it in the service mode and the dryer heated. Ran it on other cycles and no heat. I checked for continuity on the wire harness from the user interface and all wires were good. Then I tried it again and it lit for about 30 seconds and then no heat again on every cycle. It still would heat in service mode. Could it be the user interface is bad?
In Topic: Maytag Neptune washer
15 January 2014 - 07:39 AM
Yeah I meant resistor lol. Thanks for the responses boys.
In Topic: Samsung top load
18 December 2013 - 02:30 PM
I replaced the suspension and the new suspension is definitely a lot tighter and is more like a shock as the old suspension was more like springs that would bounce and not really dampen. I will give an update if the washer still has issues.
Thanks for the input it's always appreciated.
