mpm8789
Member Since 23 Oct 2012
Offline Last Active Mar 15 2015 08:32 AM
Frigidaire affinty washer lafw7000lw0
10 October 2014 - 05:10 PM
Washer is getting an e59 error. I checked it out and the tub spins freely and the motor also spins freely. I checked the motor and between pin 4-5 the resistance was around 117. Between pin 1-2 was around 2, 1-3 2-3 were around 3. So since the resistance was real close I decided to replace the motor control board. So I am still getting an e59 and I'm wondering if it is the motor or could it be something else.
duet dryer not heat ggw9250pw1
08 September 2014 - 07:50 PM
Model: ggw9250pw1
I have a duet gas dryer that wasnt getting hot.  I found that the board was not sending power to the igntor.  So I replaced the board and the igntor came on and the gas ignited.  So I left and got a call a half hour later that the dryer wasnt hot.  So I went back and found the board was not sending power again.  So I ordered another board and its on the way. I was just wondering if anyone else had this happen to them before or if anyone had any idea on why the board only worked once.
Thanks,
Michael
Maytag Neptune washer
14 January 2014 - 06:33 PM
Model MAH4000AWW.
Washer wasn't spinning and found that the wax motor was bad and the r11 thermisistor was burnt. I was looking at getting the thermisitor to repair the board and most thing say to replace r11 and q6. The q6 triac doesn't look burnt at all but I was wondering if I should replace it anyway since it is only around 8 dollars. Also I was wondering if anyone had experience repairing the r11 on this board.
Thanks for reading and thanks for any input
Samsung top load
18 November 2013 - 03:03 PM
I have a samsung top load that is getting a dc error and is not finishing the cycle the time keeps jump back up and adding minutes. When I put it in spin it will spin fine just vibrate but whenever the customer puts clothes in it she will hear the drum hit the cabinet and it will never go back into the full spin. I'm not sure what is causing this off balance so I was looking for some suggestions. Model is WA400PJHDWR/AA
Samsung washer
01 November 2013 - 12:22 PM
I have a customer with a samsung top load washer model WA5471ABWXAA.
The customer complaint is little black flakes that are getting all over the clothes and they are staining the clothes. I instructed customer to use washing machine cleaner. The customer has run the washer on the pure cycle over ten times and has used the washing machine cleaner multiple times. The customer is also using only a tablespoon of detergent. I was wondering if anyone had any solutions for me. Also I have no idea how to get the inner tub out so if someone could let me know how to go about removing the tub to clean out possibly for customer
Thanks Michael
