hesterappliance
Member Since 04 Nov 2012
Offline Last Active Yesterday, 12:25 PM
In Topic: Lg tromm WM2487HRMA Bearing replacement
31 December 2013 - 07:50 AM
auto parts stores.Are you replacing the spider.
30 December 2013 - 08:41 PM
 Have you used PB Blaster.I have done at least 40 bearing replacements.When they get that tough PB Blaster every 10 mins for 1 hour and the tub comes out. PB Blaster is the only thing that works
In Topic: How do you find freon leaks?
22 July 2013 - 07:01 PM
 I check the amps on the compressor to find if its a high or low side leak.Then nitrogen an cal blue plus.If still no luck dunk the evaporator in water.
In Topic: Dryer Vent Cleaning
25 March 2013 - 06:52 AM
 Lint eater is the best system.I have went behind others that have used blowers.Lint eater cleans all sides of the vent.
