heappliances
Member Since 09 Nov 2012
Offline Last Active Jan 08 2015 11:51 PM
In Topic: LG Dryer DLG2102W
07 December 2013 - 01:23 AM
Hi Guys! Is this issue resolved? What is the issue and fix?
We have exactly same issue. We already replaced 2 gas valves thinking 1st was defective. Same symptoms. Ignighter light up and cuts off after 15 - 20 sec. But not lighting gas. We checked everything else and all other parts seems to be ok.
Thanks
In Topic: 790.42003603 - Kenmore Convection Oven keeps beeping.
31 October 2013 - 04:16 PM
Thank you all for a great suggestions.
We are checking if the issue is resolved.
This is what we did:
1. replaced relay board - initial beeping eliminated during pre-heat. As soon as it pre-heated and temp going down, long - short beeps are continues.
2. exchanged heat sensors between lower and top. (did not installed new) - issue is completely resolved. Both units are working normally without beeping. (mystery) However, when running both ovens and turning them completely off, got "Err" displayed. No number, just "Err". It happened only 1 time and we cannot re-produce it again. Will be checking with a customer after a while.
In Topic: KitchenAit Trash Compactor Reverse Issue
27 September 2013 - 12:47 PM
This is exactly what I was thinking, but wasn't sure because its actually stops and you have to press pedal again in order to reverse.
You are guys are BEST ON THE WEST!!!!
Thank you both!!!
In Topic: LG Refrigerator lsc27926st is not dispensing ice AND water.
28 May 2013 - 11:30 AM
Thank you very much!
It was PCB.
24 May 2013 - 02:41 PM
Great point! Thanks!
We will check.
In case it will be ok, any other suggestions?
Many thanks.
