heappliances
Member Since 09 Nov 2012
Offline Last Active Yesterday, 01:54 AM
790.42003603 - Kenmore Convection Oven keeps beeping.
23 October 2013 - 12:49 PM
Good Morning/Afternoon Gurus.
We have a Kenmore Convection Oven Model #790.42003603.
Top oven on Bake selection keeps consistently beeping when heating up/ going to selected temperature.
I can hear relay clicking like it is trying on and off heating element.
As soon it is reaching desired temperature it stops.
As soon as temperature is going down, it starts consistently beeping again in a sequence of short beep (temperature selection), long beep (desired temperature reached) and supporting by relay clicking sound with each beep (short and long). No Error Codes displaying.
For me, looks like relay responsible for turning on/of bake heating element in top oven is failing on the board.
However, this dude has 5 boards:
316460300 - excluding, as it looks like it is a use interface board (Control Panel Diagram)
316435701 - excluding, as it looks like it is a power board (Control Panel Diagram)
316460201 - (Control Panel Diagram)
316443910 - (Upper Oven Diagram)
316460901 - (Upper Oven Diagram)
 Any suggestions which board is causing this behavior? I am leaning toward main board  316460901, but need your highly experienced opinion.
Thank you!!!
KitchenAit Trash Compactor Reverse Issue
27 September 2013 - 12:20 PM
Hello Gurus.
I am having issue with a KitchenAid trash compactor kucc151lss0. It is not automatically running reverse.
Issue reproduction:
1. Press pedal and it starts running.
2. Reaching end of direction and stops. Not going reverse.
3. Press pedal one more time. Start running reverse.
Is this issue related to On/Off or Directional Switch?
Thank you.
LG Refrigerator lsc27926st is not dispensing ice AND water.
24 May 2013 - 01:43 PM
Hi Gurus.
We have an LG Refrigerator lsc27926st which is not dispensing ice AND water. It is making ice. Lock button is off :)
We have a dilemma: 2 PCB - Main and dispenser.
Which one needs to be changed to resolve this issue.
Also, if anyone have a service manual for lsc27926st I would be greatly appreciated.
Thank you!
VMOR205SS Parts Diagram Needed
05 March 2013 - 10:53 PM
Hi Gurus.
Anyone have parts diagram for Viking Microwave VMOR205SS?
Need ASAP.
Thanks in advanced!
Viking VGIC3074BSS keeps sparking
11 November 2012 - 03:39 PM
Need help.
We have a Viking VGIC3074BSS which is keeps sparking on all 4 ignightors after flame is on.
We did:
1. Replaced spark module
2. Cleaned ignightors heads
3. Checked burner heads alignments
4. Checked if wires properly connected from/to spark module, ignightors, switches - correct according to diagram
5. Checked wires for any damages
After installing new spark module it was working fine for 3 - 5 min and start sparks again after.
Any help will be greatly appreciated.
Could it be problem with any switches or something else?
Thank you in advance.
