dryerman45
Member Since 13 Nov 2012
Offline Last Active Jun 17 2015 12:53 PM
In Topic: Whirlpool Washer F8E3 Error. Model#WTW4800XQ1
20 March 2015 - 08:31 PM
I replaced the valve assy ,the pressure hose and pressure switch.Have not heard back from customer after follow up
SAMANERA
19 March 2015 - 08:18 PM
In the tech booklet it asks you to check pressure hose,making sure its not pinched bent or leaking.Also test pressure switch and fill valves.Iwish one of these things was apparent but they all checked ok when testing.I dont think there is much else that can cause an F8E3 ERROR.
SAMANERA
In Topic: GE R/F Model#GSH25JFXBWW
18 March 2015 - 09:25 AM
Thank you so much,
Yes this unit does have a mylar damper.Going out to go thru steps.I will keep you guys posted.After reading the bulletin I have a feeling that I need to put in the motorized damper
SAMANERA
In Topic: BRYANT HEAT PUMP MOD#213ANA024-C
10 December 2014 - 11:37 PM
Thank you guys,
It is the outside unit that Iam referring to.The temperature outside is 40 degrees.I gues it is short cycling.I was told it isnt reversin.Does a reversing valve require sealed system work?
SAMANERA
In Topic: MAYTAG REF/FREZR.Model MFI2568AEB
16 August 2014 - 10:07 PM
Thank you guys for all the help.
I had the wrong board.Got the right one and it took 15 minutes and it was done.
SAMANERA
