dryerman45
Member Since 13 Nov 2012
Offline Last Active May 21 2015 07:38 AM
#301149 MAYTAG REF/FREZR.Model MFI2568AEB
Posted by dryerman45 on 16 August 2014 - 10:07 PM
Thank you guys for all the help.
I had the wrong board.Got the right one and it took 15 minutes and it was done.
SAMANERA
#298655 whirlpool fridge Model# ED5FHEXMS10
Posted by dryerman45 on 15 July 2014 - 06:17 AM
Thank you for the replies.
I went back and found the warm air return completely frosted up.I cleared that and some frost in the damper as well
Hopefully that will solve the problem.
Thank you very much,
SAMNERA
#291165 GE Washer WSXH208HOWW Wont start sometimes & long run times
Posted by dryerman45 on 18 April 2014 - 04:34 PM
Thanks for the replies,
I replaced the door lock Mechanism assy, and that got it working properly.Interesting that the timer doesnt advance correctly either when this door lock isnt right.As soon as I replaced it, I filled it and went to rinse spin and it spun up alot faster.Also the timer advanced properly as well.
Thank you,
SAMANERA
#290817 Samsung washer WA5451ANW/XAA
Posted by dryerman45 on 14 April 2014 - 07:58 PM
This is not an easy one.You have to go down to the hall sensor.Check continuity on all four wires from there to midway connector to Main board.What happens is the unit will run but when a vibration occurs it stops abruptly and you get DC error.I had one of these and we are samsung authorized,and had to pull it into the shop.I eneded up telling them.So again the hall sensor from there to the connector midway up the back.Then from there to control board.I found the Green wire open coming from hall sensor to connector in back.
Let me know
SAMANERA
#290706 Whirlpool washer model# WTW57ESVWO
Posted by dryerman45 on 12 April 2014 - 09:33 PM
Dear Samurai's,
I replaced the timer assy and that took care of this bad design washer in my opinion.Thanks for everybodys input
SAMANERA
#283315 FRIGIDAIRE WASHER NO SPIN
Posted by dryerman45 on 03 February 2014 - 05:30 PM
Dear Fellow Samurais,
Thank you for all your input.I replaced the door lock mechanism assy, and she spins like a champ.It was locking but would open up almost as soon as you unplugged it.Thanks for that tip SOHEI.The erro code was an E41 which means the control board doesnt see the door as locked.Thank you for the tech sheet info SENPAI..
SAMANERA
#278933 GE WASHER NO SPIN
Posted by dryerman45 on 26 December 2013 - 05:08 PM
Dear Samurai's,
Thank you for the answer.Went back and the pressure hose was almost completely restricted at the airdome.Cleaned it out and works great
Thank you,
SAMANERA
#271638 DEAD WASHER
Posted by dryerman45 on 20 October 2013 - 11:27 AM
Thank you for that reply.I went back to this customer and replaced the CCU Board and that solved it.
SAMANERA
#270165 KITCHENAID OVEN ,MICROWAVE COMBO
Posted by dryerman45 on 04 October 2013 - 04:36 PM
DEAR FELLOW SAMURAIS,
The new inverter I received turned out to be the problem.I went to customers house with a new invereter and replaced it.The original new one on close inspection had a hairline crack across  most of the traces.The problem I had was that I assumed the new part was ok,when it never was.This created a whole slew of additional part orders and trips.So I will be examining ever part especially electronic circuit very closely.Thanks for all your input
SAMANERA
#268461 Kenmore washer won't spin
Posted by dryerman45 on 16 September 2013 - 08:49 PM
lid switch
#262515 FRIGIDAIRE DRYER INOP
Posted by dryerman45 on 25 July 2013 - 09:51 PM
Yes master is was main control: http://www.repaircli...ber=AEQB6400FS0
SAMANERA
#262323 FRIGIDAIRE DRYER INOP
Posted by dryerman45 on 24 July 2013 - 09:03 PM
Thank you for the help.It turned out to be the main control board up front of unit.I did check voltages at wall ,and at terminals before and they were fine
SAMANERA
#253597 DEFROST HELP.MODEL#HSS25GFPAWW
Posted by dryerman45 on 02 May 2013 - 08:56 PM
Dear Samurais,
I have a Hotpoint ref freezer and the heater is bad,one wire connected to it is burnt to a crisp and the element is open.Iam going to change the thermistor sensor and the thermostat as well on this repair.I guess Iam afraid that there is something Iam missing and donbt want a recall.Any tips on how to test to make sure it is working before I leave customers home.Or what some of you pros do to avoid recallS on defrost type problems.
SAMANERA
#253090 SAMSUNG FRONT LOAD WASHER
Posted by dryerman45 on 25 April 2013 - 11:44 PM
Hi Fellow Samura's,
Just an FYI on this unit.Went back to customers home and determined that the basket is actually out of round.Put it in hi speed test and the machine went kinda bizirk.Its actually not an bearing or spider its the shape of the basket.Unbeleivable.How cheaply are these things made for something like this to happen at 2.5 years old.Afgter I did the test I spun the drum around by hand and you can see that its sort of oblong,out of round and you can hear it scrape the tub.This is whats been chewing up the boot..
SAMANERA
#252831 SAMSUNG FRONT LOAD WASHER
Posted by dryerman45 on 22 April 2013 - 07:19 PM
Master,
I have an Samsung washer front load.Model# WF328AAW/XAA.The customer is complaining that they are getting
a burning smell.I noticed the boot seal is being chewed up and some of it ended up in the washers drain access.It also starts to rattle and vibrate alot at the end of cycle,hi sppeed spin.Wanted to know if you have run into this problem before.
Thanks,
SAMANERA
