longtimer
Member Since 19 Oct 2006
Offline Last Active Sep 25 2012 04:44 PM
In Topic: Maytag Washer Model A25CS keeps over filling with water
13 October 2011 - 07:42 PM
Bad pressure switch
If the hose is clear and no holes
Not much else it could be
Bad pressure switch
In Topic: Icemaker for GE refridge model #TBX21CIBLRWW not working
13 October 2011 - 07:23 PM
Another antique from the 80's
If the water valve is good and no obstrution in the fill lines
Then replace the head
In Topic: GSD1200G06 doesn't drain
11 October 2011 - 11:03 AM
This dishwasher is so old, I remember that model. The drain plunger can be manually pulled down anytime the motor is running.
Should hear a pretty good thud if there is pump pressure.
The collection box under the plunger is where most debris collected.
In Topic: noise Maytag dishwasher MDB7851AWB
07 October 2011 - 08:47 PM
... why the reducing Valve ?
from the Maytag DishWasher installation manual:
Water Supply Requirements
■ A hot water line with 20-120 psi water pressure.
20 psi min will not let enough water in.sounds good but will not work
Reducing valve was on the whole house system, I guess the plumber needed more billables.
Not really needed, system had a 70 psi static pressure, a little high but not hammering.
The sump on this stainless steel tub dishwasheris very shallowand a very slight tilt forward allowed pump to dry sump.
Here is the real rub.
Extended warranty company paying bill, but not this one because there was nothing wrong with dishwasher.
Kitchen installer installed d/w incorrectly and plumber compounded the issue.
I will send a bill, but it will never get paid.
4 trips 5 hours total time invested,,zero revenue
Sometime this job just sucks
In Topic: GE dishwasher GLD4560N10SS New Control Board Installed & Still Wacked
07 October 2011 - 05:42 PM
check to make sure you have a GOOD ground.
open grounds make boards do goofy things
