longtimer
Member Since 19 Oct 2006
Offline Last Active Sep 25 2012 04:44 PM
#211108 Icemaker for GE refridge model #TBX21CIBLRWW not working
Posted by longtimer on 13 October 2011 - 07:23 PM
Another antique from the 80's
If the water valve is good and no obstrution in the fill lines
Then replace the head
#210380 noise Maytag dishwasher MDB7851AWB
Posted by longtimer on 07 October 2011 - 05:36 PM
Ok, just in case some of you want to know a resolution to this problem.
1. water pressure was low static was 44 psi and dropped to less than 24 psi with fill valve open. customer had a pressure reducing device on and I ended up adjusting it higher. (if you added 12 oz of water manuall noise went away)
2. water level fine now, but noise continued even louder , still a dry sump and water level good.
3. d/w was tilted a little forward (top of d/w out) I remounted and leveled (not much 1/4 inch)
4 Wa La......noise gone, no more dry sump noise
I never would have expected a result as leveling that little could have made a big difference.
recap
replaced fill valve no good
disassembled and cleaned pump no good
check all wash arms no good
increased water pressure (an option most do not have avail) no good
tilt d/w 1/4 backward and problem gone
will remember this one after 4 trips
#62228 Why do Dryers cost so much?
Posted by longtimer on 21 December 2006 - 06:21 PM
Your first mistake is to infer manufacturing cost determines selling price. They are not linked like you think and seldom are. Market determines selling price and profitability determines selection and availability. Simple econ 101
