tonybeth103
Member Since 20 Nov 2012
Offline Last Active Dec 12 2012 04:38 PM
#243653 Help with my Soda Machine Fridgeration
Posted by tonybeth103 on 06 December 2012 - 05:01 PM
Ok.  Well I hooked it up to a regular wall outlet and both fans kicked right on! :rocker:
Now I have to figure out if it is getting cold ie and to charge it with freon.
my father inlaw has the line for charging but I think I need to know what type of freon to put in.
Any suggestions?
THANK YOU ALL AGAIN FOR YOUR HELP!!
Trying to find what else I can fix so I can keep posting.
Tony  :thanks:
#243493 Help with my Soda Machine Fridgeration
Posted by tonybeth103 on 03 December 2012 - 09:08 PM
do not use anything you have there
get a 3-1 starter and wire according to instructions that come with it
3-1 will have 5 wires , 3 of them just plug right on to the 3 pins in your compressor with the pre installed connectors
the 2 bare black wires are just power , connect them to the power cord along with the condenser fan motor leads
it's just that easy
when your shopping for one you want one that will work with the horse power(HP) of the compressor you have, in your case you have a 1/3HP compressor , there is a 3-1 that works with 1/4 -1/3HP compressors , that's the one you should buy
Hello Again,
Well my 3-1 start came today.. So this is my question from your instructions.
____
With the blacks from the 3-1 that are not pre-pinned.
I connected one black from the 3-1 to one black from the fan on the condenser and one black one the compressor. Then
I connected other black from the 3-1 to other black from the fan on the condenser and the other black on the compressor.
I have a cord coming from the (looks like thermostat) has a white and black and ground.
NOT SURE WHAT TO DO WITH THOSE?  :whistling:
Thanks again for all your help.. ALL OF YOU!!  :thumbsup:
Tony
#242943 Help with my Soda Machine Fridgeration
Posted by tonybeth103 on 22 November 2012 - 09:26 PM
Attached File  Slide1.jpg   86.88KB   20 downloadsAttached File  Slide2.jpg   94.92KB   19 downloadsAttached File  Slide3.jpg   40.92KB   10 downloadsAttached File  Slide4.jpg   59.98KB   5 downloads
OK I hope this works Trying to upload photos I made of the parts.
SODA MACHINE MODEL: VFA56-B
COMPRESSOR has 2 black wires
AE530-AR-718-J7
AEA3425YXA
POWERSTART has 4 wires (2 reds and 2 blacks) (not sure if this is the right relay or not.
URSC10
FAN TO RADIATOR?(I think it is a condessor) has 2 black wire s
5KSP51AL327H
HAPPY THANKSGIVING AND THANKS AGAIN
