KCTBURY
Member Since 02 Dec 2012
Offline Last Active Yesterday, 02:52 PM
In Topic: Kenmore Washer 110 44832 200 Not spinning clothes completely?
28 January 2015 - 11:34 PM
Pull the pump assembly out and the hose behind it. The one that goes from the tub to the drain.  There is a white "float" ball in there. Make sure that hose is clear and there is no obstruction between the tub and the ball, like a sock. Check the hose from pump to wall.
In Topic: Inksinkerator Badger 5 plus-7 died; how much hp do I really need?
04 December 2014 - 01:13 AM
There is a badger 15ss with stainless steel parts inside. This unit comes with a 3/4 hp motor. This model is great as most units rust out and leak..... The more hp you have isn't a great idea..... if you need more than 1/2 hp to chop something up then is shouldn't be going down your drain; Rather in the trash. If they had a stainless steel 1/3 or 1/2 it would be good, but i'm not aware of one.
In Topic: 110.47531701 kenmore front load washer f20 code
18 November 2014 - 01:18 AM
Perhaps the flow meter? There are tons of posts here related to the f20 error though...
In Topic: Electrolux EIFLS55IIW0 error E21
14 November 2014 - 08:46 PM
       That is the hard way to do that repair.... You can go through the back panel real easy, or through the bottom if you drain the water first,  Did you take the white basket out of the hose that goes to the pump and clean it out?
In Topic: Whirlpool LXR6232EQ0 goes throught 1st cycle only
12 November 2014 - 11:16 PM
No its the drain pump. Your lid switch needs to be replaced also because you taped it together, but that is not the problem here.
In the first post i posted a link. Follow that link and there is a video at the bottom of the page showing you step by step on how to complete the repair.  Make sure you drain the washer by putting the drain hose at a lower level then the tub. There is a lot of water in there so make sure you prepare correctly.
Here is a link to the lid switch.
Part number: 3949247
