KCTBURY
Member Since 02 Dec 2012
Offline Last Active May 29 2015 03:55 PM
Rs265tdrs Samsung refrigerator frost on fan
27 February 2014 - 03:29 PM
I'm getting frost buildup at the bottom of the evaporator fan blade area on the refrigerator side.
No frost build up on the evap coils. Door seal is good. Heater test at 105 ohms. Thermistor on evap test good. Unit does defrost.
Help! Unit is 2 years old !! Got to love Samsung.
I'm such a dolt! I see this topic a few threads down please remove post!
WF328AAW/xaa no drain
11 February 2014 - 11:20 PM
Not sure if my searching the site abilities are fail or if it's no posted.
WF328AAW/xaa no power to drain pump.
Can you link the pcb?
Not sure if it's the one in the back or front.
Jennair diswasher jdb3200aws2
30 January 2014 - 04:29 PM
Dishwasher not cleaning well
I don't see an impeller on the parts diagram. Does the pump motor need to be replaced?
Second problem
1 hour wash will run for about 5 min and then shut down.
You Think You Have Seen It All and Then....
02 October 2013 - 12:57 AM
I have some Crazy repairs...... Anyone else run into crazy situations?
My day started with a fridge that's not cooling properly,
I open up the freezer and quickly ascertain that the evap fan is not working but the inside of the freezer smells Fresh! Fresh like clothes straight out of the dryer.
I pull the back panel off to replace the evap fan and see that something is cuaght up in the fan. Low and behold its a stack of dryer sheets! After talking to the customer she claimed to like the smell so she wanted her fridge to smell like that and shoved the dryer sheets in there up at the top of the freezer section! Then ask do I have to pay for this? LOL hell yes!
Bosch Dishwasher shu6800
18 September 2013 - 11:32 PM
Working on a Bosch Dishwasher.
Model Number SHU6800
When you press the power on button the dishwasher starts to run with 13 min on the timer.
The Timer counts down and nothing happens except the circulation motor runs.
None of the buttons will work on the panel
The motor runs but the water is not being moved.
My first instinct is the circulation motor but why does it all ways start with 13 min?
Doesn't drain or anything!
Can not get into test mode either
