murfndbox
Member Since 03 Dec 2012
Offline Last Active Dec 16 2012 08:58 PM
In Topic: Whirlpool Washer 110.92591200 does not drain completely
15 December 2012 - 04:09 PM
Just received and installed the new timer. First use, it failed to drain the tub completely and just seemed to stop(timer too). My son accidentally let go of the washer lid where it slammed a bit and the washing machine finished its cycle. Do you think it might be the lid switch? I thought those either worked or they didn't. Can they fail mid-stream?
You also mentioned that if the motor stopped, it might be overheating. Since the timer stops too, is that likely to happen?
05 December 2012 - 08:30 AM
Sorry for the delay - My son's washer and I was traveling. One correction - It is a Kenmore not a Whirlpool (my bad). I watched the washer through two different complete cycles (UltraClean Wash; Normal Wash - 2nd rinse switch not set for either cycle) and it worked perfectly. My son says that it fails 99% of the time when they use it. When it stops, they say it leaves 2-3 inches of water in the bottom of the tub. He says they can usually play with the controls and after 2-3 attempts get the washer to finish. Is it possible for the timer to fail intermittently? I'm wondering if sometimes it stops prematurely. I will post more once they can get it to fail for me to observe.
