appliancecare
Member Since 04 Dec 2012
Offline Last Active Today, 02:27 PM
In Topic: Whirlpool Washer WTW8800YW0 Leaking
Today, 02:17 PM
I found a technical service pointer.  #:W10545059A  this addresses a bleach overfill problem on Cabrios but my model # is not listed,  Doesn't say anything about fab soft disp.  The service pointer says there is a new dispenser.  Should I just order and replaced the dispensers?  Also the customer has been using the machine on a cycle and selection that does not use these dispensers with no leaks...
In Topic: Frigidaire dryer FSE48GFS0 thermal fuse
05 January 2015 - 10:21 AM
Correction on model #.  FSE748GFS0.  Thanks for all the replies.  I have replaced the front felt glide before. That's seems fine.  I have not changed the cycling thermostat.  I checked cycling temp at the vent outlet at the back of dryer.  Dryer thermostat seems to cycle fine and the exhaust/air flow is strong.  I haven't checked the motor by hand or the blower wheel I'm just assuming, because it runs quietly and exhaust fine, that these are okay.  I will try cycling thermo and check these other things and let you know.
Thanks, Jim
In Topic: Maytag Dishwasher MDB7709AWQ2 lights on/no run
27 September 2014 - 10:50 AM
Thanks for info.  Turned out that the control board was bad.  Ordered new board and installed.
Thanks again.
Jim
In Topic: LG Washer WM2350HWC Washability
15 August 2014 - 05:44 AM
Thanks for all the responses.  I'll talk to my customer and find out and suggest these things.  I'll post my results.
But pretty much it can't be a fault of the machine?  It has to be user error?
Thanks
In Topic: Samsung Refrigerator RB1944SL/XAA Not Running
23 May 2014 - 04:36 AM
Thanks Durham and everyone.  Turned out to be a bad Thermal Fuse in freezer.
Thanks for all the help!
