appliancecare
Member Since 04 Dec 2012
Offline Last Active Jan 29 2015 01:23 PM
#312304 Whirlpool Washer WTW8800YW0 Leaking
Posted by appliancecare on 29 January 2015 - 01:24 PM
Thanks.  I have ordered bleach dispenser above (Part number: W10187307
) and fab soft disp. Part number: W10172146
.  Parts not in stock from my vender so it will be about a week but I will post the outcome.
Thanks Again
#294367 Samsung Refrigerator RB1944SL/XAA Not Running
Posted by appliancecare on 23 May 2014 - 04:36 AM
Thanks Durham and everyone.  Turned out to be a bad Thermal Fuse in freezer.
Thanks for all the help!
#283770 Maytag Refrigerator MFI2269VEA1 Water Dispensing Problem
Posted by appliancecare on 07 February 2014 - 09:41 AM
Thank you guys!  I will give that a go and let you know how I make out.
Thanks Again, Jim
#281905 GE Gas Range JGBP90MEB3BC Broiler not burning clean
Posted by appliancecare on 20 January 2014 - 05:27 PM
Update:
Went today and installed the new orifice.   WB28K202 with the green band.  Everything working fine.
#276431 Thank You For All Of The Help YOU Have Given Me!
Posted by appliancecare on 05 December 2013 - 07:32 AM
Great to see this post!   I own a small (1 man... ME!) appliance repair company.  I came across this site about 2 years ago I guess.   It has saved me banging my head against the wall many times!  Even with 30 years experience in this biz there are those times you need some help.  Manuals, tech sheets, part number and of course the occasional  "What the @#%& is this!" question.  I try to contribute to the beer fund when I can.  This post has reminded me to head over there and buy you guys a beer.  Great Job. Much Much Thanks!!!
Jim G.
Appliance Care
North Branford, CT
#271408 Maytag Washer MTW6700TQ1 F-71 Error
Posted by appliancecare on 18 October 2013 - 05:47 AM
FYI... I had to replaced the drive hub part # 280145 and bearing kit part # W10435302 to solve this problem.  Works fine now!  Turns out that it was stopping mid cycle and giving an OS code too.
#253040 Woods Upright Freezer Frozen Drain Tube (again)
Posted by appliancecare on 25 April 2013 - 12:42 PM
Ive used the gh250 on some older models.  It works good.  I beleve you wire it in parallel with the evap fan motor so that when the unit cycles into a run mode the heater comes on to keep the drain from freezing.  I also use the GE wr2x9393 heat probe. Its basicly a flexable piece of wire that you stick down the drain line and then wrap it around one of the evap coils next to the defrost heater.  U can then form the wire to run next to the defrost heater, glass or calrod. The wire will conduct heat from the def heater when it goes into def cycle.
