k2ue
Member Since 13 Dec 2012
Offline Last Active Dec 13 2012 11:56 PM
In Topic: LG Icemaker Problem
13 December 2012 - 03:42 PM
There is no supply line filter (the main supply is filtered thru a carbon block filter, and other users flow OK).  So doesn't that leave a frozen fill tube or a plugged solenoid valve?
13 December 2012 - 03:33 PM
It does not fill during the fill phase of the test, even though it sounds like it is.  How do you clear a frozen fill tube -- If that isn't it the valve must be bad.
