Magenta#90
Member Since 26 Dec 2012
Offline Last Active Jun 13 2015 10:26 PM
In Topic: MAYTAG MEDB850WQ0 DRYER CO Error Code
23 April 2015 - 07:37 PM
I did went back, I checked the voltage at P2-1/P2-3 around 4,93 Vdc from the User interface to the control, and because should be around 5Vdc-12Vdc, I thought should be enough, I was wrong. I installed the control board first, same result " CO" error code. Then I installed the new user interface an the dryer  worked , I run diagnostic and went through after 8:88 count. Unfortunately  the customer had to pay for both parts, I was wondering that if the voltage at P2 should be more than 5 Vdc  if less the UI could be bad. Anybody knows of a voltage spike suppressor for 240 Volts. Thank you.
In Topic: MAYTAG DRYER MDG8400AWW SENSOR 33002095
19 December 2014 - 08:49 PM
Sorry, the part number is Part number: 33002905
, 14 pin connector.
In Topic: Sub-Zero 511 refrigerator S/N M114......
01 December 2014 - 11:04 PM
Any parts supplier I can contact, I tried everybody. Thank you.
29 November 2014 - 10:12 PM
I was incorrect before, the problem is with the Refrigerator drain that freeze after 2 0r 3 days , not the freezer drain, is possible that the controls in the refrigerator close too fast? thnk yo
In Topic: whirpool ref. GI7FVCXWY00 ice maker overflow
28 August 2014 - 08:47 PM
which water valve, the one in the upper refrigerator section or the inlet valve that shows at the bottom?
