Magenta#90
Member Since 26 Dec 2012
Offline Last Active Apr 23 2015 07:39 PM
#272286 AMANA Refrigerator Mod.36271 P1121801WW
Posted by Magenta#90 on 26 October 2013 - 05:45 PM
Good news, found the problem, yellow wire to the evaporator motor  short to the frame and also another red wire short to the frame due  to the sharpened corners of the evap bracket,  Now the cold control able to shut the compressor. Thanks to everybody.
#265570 WTW4950XW1 F7/E1 error
Posted by Magenta#90 on 21 August 2013 - 06:36 PM
Got the machine in my shop, found broken red wire in the wire-tie down  point of the red coil wire , since she gave to me after less than 2 years, i'm going to use for training.
#264680 MAH4000AWW,
Posted by Magenta#90 on 13 August 2013 - 09:37 PM
MCU  was bad, 2 or 3 burns on the control, we will install a new conversion kit. thanks.
#252749 Maytag Neptune TL FAV6800A
Posted by Magenta#90 on 21 April 2013 - 03:24 PM
Fills the first time, in rinse mode shows "NF" code, isn't filling the second time. Possible bad Control or Bad inlet valve or pressure switch any advice , thanks
