Magenta#90
Member Since 26 Dec 2012
Offline Last Active Jun 13 2015 10:26 PM
GE GSS30C6EYY01 Icemaker IDI freezing water line in door
03 June 2015 - 08:17 PM
3 years old with the 6 sense system, no water coming into the mold of the IM inside the  door  top portion line is frozen. cannot put a flexible line and squeeze hot water inside tube. should the customer defrost for 2 days and see if problem disappear anyone having the same problem with this Hi-tech garbage?...
MAYTAG MEDB850WQ0 DRYER CO Error Code
20 April 2015 - 09:21 PM
Customer complains that when came back home the dryer was on, also  the other appliances show Power Failure due to power  loss in the street. Tried to activated the diagnostic test modes  but most the time shows "CO" error, tried Manual  load test, nothing, I'm lost I talk to several technicians, some say the control board, the harness or the User interface. Us we know there  is no CO error in the tech sheet, I'am able to activate the diagnostic test mode until the "8:88" after the "8:88" the console goes Blank, but doesn't come back with the "8:88: displayed, sometimes I get the "LID.  Please Help..........
HAJER RDE350aw dryer nor running.
28 January 2015 - 06:54 PM
Is this a Frigidaire copy? Is anybody familiar, thank you
Whirpool made Kenmore 665.13963k015 F2e2 error code
23 December 2014 - 10:43 PM
I went to the customer home, found inlet pump loose from the clamp. I decided to replace the sump pump assembly because maybe something wrong with the pump, and since a had a pump on my truck It  would be faster, I guess I was wrong. After installation  still the F2e2 came back, so now I don't know if needs a new control board, User interface or turbidity sensor. Also could be the  wiring harness, after 3 years she may have to buy a new one. The sump pump  I replaced has a different number but looks the same the keyboard doesn't  respond sometimes only the cancel key works, i' lost at this point, anybody having luck with this new generation Whirpool dishwashers ?. Thank you for your Help.
MAYTAG DRYER MDG8400AWW SENSOR 33002095
15 December 2014 - 08:59 PM
ordered THIS SENSOR  from my supplier and still waiting, i'm afraid  they don't make anymore, anybody knows where can I get one part# 33002095.
