LauraC
Member Since 13 Jan 2013
Offline Last Active Jan 30 2014 02:17 PM
Fisher Paykel GWL 11
27 January 2014 - 01:59 PM
Hi,
Well, we just fixed our FP dryer, now onto the washer!! GWL 11 washer. Makes horrendous noise during spin, and when we moved washer out of way  to fix dryer, discovered brown sticky goo sprayed in a circular pattern under washer. Guessing bearing?
Need to find part and detailed instructions. Something about a special tool needed???? Any help appreciated!!
Thanks!
Laura
Fisher Paykel GWL11
13 January 2013 - 11:46 AM
I have a FP GWL 11 washer. I will describe the problem as best I can...
When the washer gets to the rinse cycle, the agitator shifts a few inches back and forth repeatedly and eventually it begines beeping at me. The clothing is very wet, but it appears the washer is draining. If I go directly to spin, it will not spin, but does the same thisng, agitator shift back and forth about and inch in each direction. I did a diagnositc and all lights were off - no codes. Any ideas???
Thanks!
