peppie2013
Member Since 16 Jan 2013
Offline Last Active Jan 17 2013 05:13 PM
maytag dryer MEDC400VWO, wired wrong. starts then turns off
16 January 2013 - 12:43 PM
This dryer was wired wrong when changing over to a 4 prong plug. Once properly wired, when it is turned on the thermal protector on the motor makes a loud noise and then trips out and the motor stops. After 10 minutes or so it will rest and the motor will start again and repeats problem. I have tried it with the belt off and the drum removed. Is the motor burned out now?
