LIONL56
Member Since 25 Jan 2013
Offline Last Active May 09 2013 07:05 PM
In Topic: timer not advancing roper dryer mod nvl333eb6ww
15 March 2013 - 05:20 PM
Also a bad sensor board if unit has one, or bad coils, Many times i find coils don't fail right away, run unit on high heat, time dry, check coils, What is model & serial #.
In Topic: GE F/L WASHER
11 February 2013 - 10:12 PM
Because of the on going problem, we decided 2 order, hose, presure sw, main board. WILL CHANGE PARTS IN THAT ORDER BETWEEN TESTS. PROBLEM GOING ON 2 LONG, WITH 2 MANY COOKS IN THE KITCHEN, THANKS 4 ADVISE, WILL UPDATE
In Topic: Hose clamp pliers
11 February 2013 - 09:34 PM
   Or maybe one of thesehttp://www.aspensafe...IUNG/TOOLS.htmlshapeimage_5.png
Thanks 4 the info, will check it out
Hose Clamp Pliers
click on picture
where can u buy a pair.
In Topic: Whirlpool Top load Squeals in agitation like a stuck pig!
06 February 2013 - 11:01 PM
Its most likly one of 2 things, sus rods, or trans and seal, check the obvious, then spin basket by hand in each direction slow, if u here squeal, its from seal, I replace trans with new seal, under warranty
04 February 2013 - 10:09 PM
After diag,that was my thought, didn't want to jump the gun on this one. Thanks to all u guys, will replace presure sw, will up date, thanks
