LIONL56
Member Since 25 Jan 2013
Offline Last Active May 09 2013 07:05 PM
#250145 timer not advancing roper dryer mod nvl333eb6ww
Posted by LIONL56 on 15 March 2013 - 05:20 PM
Also a bad sensor board if unit has one, or bad coils, Many times i find coils don't fail right away, run unit on high heat, time dry, check coils, What is model & serial #.
#247877 Whirlpool Top load Squeals in agitation like a stuck pig!
Posted by LIONL56 on 06 February 2013 - 11:01 PM
Its most likly one of 2 things, sus rods, or trans and seal, check the obvious, then spin basket by hand in each direction slow, if u here squeal, its from seal, I replace trans with new seal, under warranty
#247444 Whirlpool Washer
Posted by LIONL56 on 31 January 2013 - 12:19 AM
REPLACED MANY, ANOTHER SIGN IS WHEN IT STARTS FILLING 4 A FEW MINUTES, AND THE UNIT DOES NOT AGITATE 4 A FEW SECONDS TO GET CLOTHES WET 2 PROPERLEY SENSE THE WATER LEVEL
