LIONL56
Member Since 25 Jan 2013
Offline Last Active May 09 2013 07:05 PM
FRIGIDAIRE L CENTER- FFLG2022MW0
04 March 2013 - 11:15 PM
After cycle ends, lid unlocks, then locks and starts another cycle, I thinking main board.
Hose clamp pliers
06 February 2013 - 11:22 PM
Looking for a small hose clamp pliers, Had a nice pair,broke,  about 6 inches long, perfect for tight areas, especially  good for clamps used on w/p pumps, bought in appliance parts store, they can't get them anymore, any recomendations, thanks
GE F/L WASHER
04 February 2013 - 01:16 PM
Unit starts, pump runs, fills with a little water,rotates fills with again, then stops in mide cycle. Checked codes, e38, e23, e61,e60,e46. Did manual test test mode, found presure sw test not responding properly, checked presure hose, pr sw harness, ok. cycle tested, worked properly once, then same problem, 3 other service company came out prior, i don't give up easily, any ideas, thanks
whirlpool vmw washer, no model #
31 January 2013 - 10:28 PM
RAN DIAGS, NO CODES, START UNIT, FILLS, AGITATES PROPERLY, LED LIGHT NEVER GOES TO WASH, STAYS ON SENSING, VERY SLOW AGITATION,SPINS PROPERLY.  NEED ADVISE, THANKS
