FriginDare
Member Since 12 Feb 2013
Offline Last Active Mar 06 2013 12:10 PM
In Topic: Frigidaire ATF6000ES1 - Drains but does not spin
06 March 2013 - 12:08 PM
I wanted to post a quick update:
I ordered the Door Latch Assembly from Repair Clinic, and it was shipped and arrived quickly. I am very happy with their service and would recommend to others.
After installing the new part I have been running the machine for about 2 weeks now and it seems to be working perfectly. Thanks so much for all your help.
One last question, is there anyway to rebuild/repair my old Door Latch Assembly so I can use it later?
13 February 2013 - 05:47 PM
Awesome, thanks for the quick replies!
I turned the washer to the Spin Only cycle and tested the door with the power on. It was locked and did not open.
Then I unplugged the power cord and right away I was able to open the door.
So I guess I will be ordering a new Door Latch Assembly...
Thanks for the advice and I will follow-up after I install the new part!
Edit: Just took a look at repair clinic and they say I may need a new wire harness and door strike. Should I order these with the Latch or just if it does not work after I install it?
