jcramer
Member Since 14 Feb 2013
Offline Last Active Jul 12 2013 03:40 PM
In Topic: ASKO T721 Dryer does not start when start button pushed
30 April 2013 - 10:21 AM
Thanks for the reply. I will check it and order a new start capacitor if I need to.
I have not tested it I have just been starting the drum manually and that works but it would be nice to get it working normally.
A repair tech told me I needed a new motor but that did not make sense to me since it works if i just get it started turning.
Jerry
In Topic: ASKO T721 Loose white wire
13 March 2013 - 08:55 AM
Well I ended up calling a repairman for this issue.
It turns out that ASKO prints codes on the connector ends of the wires which match up to numbers on the wiring diagram.
The service man traced every wire on the diagram only to find that the plain white wire was not included on the chart nor was it marked with a number to indicate its place on the chart.
The service man called ASKO tech support  who identified where the wire was to be connected.
Which turned out to be the second post down on the upper relay (high heat relay).
Sorry I did not respond sooner. I had plumbing issues which took precedent over the dryer issues.
Dryer is working now at least as well as it worked before the belt broke.
I still have an issue but i will open a new thread for that.
Jerry
06 March 2013 - 12:57 PM
I looked for a connector that looked scratched but could not tell anything. I am still looking.
Thanks for the suggestion
Jerry
