jcramer
Member Since 14 Feb 2013
Offline Last Active Jul 12 2013 03:40 PM
ASKO T721 Dryer does not start when start button pushed
13 March 2013 - 09:05 AM
I have an ASKO T721 dryer. When I push the start button it buzzes but the drum does not start rotating.
If I wedge the door switch and use my hand to start the tumbler running manually it works perfectly.
In fact I dried 3 loads of clothes last night this way.
I know this machine has a "start capacitor" . Is this capacitor to surge the motor to start the drum turning?
If this is true I may need a start capacitor and not a motor.
Any thoughts?
Thanks in advance.
Jerry
ASKO T721 Loose white wire
06 March 2013 - 09:39 AM
I replaced the belt kit on my ASKO T721 Dryer. In the process I knocked off one of the wires that connects to the back panel. It is a solid white wire and looks like the only solid white wire. It is within reach of about a half dozen terminals it could be connected to on a bar connected to the back with a lot of wires.
This bar is marked N but I do not see any indication on the circuit diagram TD22 as to what colors connect to this N.
I called ASKO and they could not tell me. Just said call a service tech.
Talked to service tech and he did not have any idea either.
Is there a color coded diagram anywhere to match Circuit Diagram TD22 or does anyone know where I should reconnect the solid white wire on the back panel of this dryer?
I have pictures of the wires but they are too big to upload I will try to resize them.
Thanks in advance
Jerry
