nomoney
Member Since 09 Mar 2013
Offline Last Active Mar 30 2014 10:40 AM
In Topic: GE stack wont advance to or out of spin
28 March 2014 - 09:10 AM
The manual doesnt show the timeline for the washer and it doesnt have a flowchart to troubleshoot the washer.
It has both for the dryer and service mode info for the washer but without much explanation.
In Topic: kenmore sxs ref
01 April 2013 - 04:03 PM
Diddnt change anything.
Owners decided to sign up for Sears contract.
Diddnt use recorder. No sunlight on frig. No range next to it.  They have second ref filled up as well.
All good points....
 The first trip I made, I figured the kids were swinging on the doors before mom got home but no proof.
Anyway, if I find out what Sears does I"ll post it.
In Topic: Killer Kitchenaid Fridge md.KSSP48QKS00
01 April 2013 - 03:35 PM
" and they also complained about water spilling on the floor."
If you still have the water issue....
Was the water on the FF side?  If so check the water resevoir tubing (behind crispers in FF). Sometimes they split or the fittings get loose.
If the water is coming from the freezer side.... check the water dispenser tubing going into the bottom of the freezer door.
30 March 2013 - 10:07 AM
After all consideration and looking over the data, I condemmed the compressor. The frig is in a rental and the comp is under warranty.
The owner of the house called Sears and set up a service date with them. The outcome is yet to be seen.
In Topic: Whirlpool Undercounter dishwasher DU810SWPQ4
27 March 2013 - 05:26 PM
Went by today.
Same trouble as last time. Knob was stuck in the control panel. Removed timer and had to tap knob to free it from the hole.
I guess I was brain dead or something because I couldn't figure out how to get it OUT!
Looks like a couple of tabs on the side but was unable to free it when I used a scewdriver to flex them outa the way.
I did free it up again but figure the KNOB replacement is the best idea.
Any words of wisdom on the knob removal??
