Applianceman97
Member Since 12 Mar 2013
Offline Last Active Yesterday, 11:53 PM
#316324 Samsung dryer dv431aewxaa0
Posted by Applianceman97 on Yesterday, 03:06 PM
Thanks for the update brother!!!
For future readers.
Part number: AP5325135
#316282 Hot point refrigerator m/ hss25ifmd
Posted by Applianceman97 on 25 March 2015 - 07:32 PM
No need to be sorry brother. Just remember this for in the future. It will make your life easier and you will get faster at diagnosing those units.
#316187 Whirlpool WTW4950XW0
Posted by Applianceman97 on 24 March 2015 - 08:41 AM
http://appliantology...ittent-failure/
Part number: W10006355
#316179 Hot point refrigerator m/ hss25ifmd
Posted by Applianceman97 on 24 March 2015 - 12:18 AM
So didn't check the thermistor the first trip? WHY NOT!!!??? What controls defrosting in this refrigerator? THERMISTOR.
You said the thermistor was out of spec. What was it reading? Sorry if I seem a little agitated but if you have a defrost issue you have to check the components in the defrost circuit.
When the refrigerator is on, is the evap fan quickly changing speeds/howling? I have seen many of these encoder units where when it's turned "off" the evap fan would still run. I know on some of the GE units they did change them so the evap fan would run when the compressor and condenser fan were off. Not sure actually have a main board failure. Could just be a thermistor issue.
Hopefully brother Durham or the Samurai can chime in. They are the GE experts. I see quite a few, but not near the amount they do.
#316133 whirlpool /k.aid dual evaporator models
Posted by Applianceman97 on 22 March 2015 - 01:04 PM
I cringe at just "whirlpool". You don't even have to make it to the dual evap part.
#316074 Samsung Fridg RB195ACBP/XAA
Posted by Applianceman97 on 21 March 2015 - 10:25 PM
Who are the Samsung Guru you talked to? Brother spanner posted the correct parts above.
If the ONLY difference of the parts you have is the connector then yes you can splice. Make sure to seal the connectors with a waterproof sealant. But now I ask why splice when the parts you need are listed above. A much easier option. Plug and play.
#315587 JBP67BODWWH intermintant no power at clock.
Posted by Applianceman97 on 16 March 2015 - 09:48 PM
Sounds like an electrical problem to me. Had the exact same issue with a Frigidaire. Double Check for 240v.
#315425 Samsung dryer dv431aewxaa0
Posted by Applianceman97 on 14 March 2015 - 10:05 AM
Only way I know to get them is with the drum.
#315340 Bosch oven HBN455AUC manual
Posted by Applianceman97 on 13 March 2015 - 08:32 AM
Thank you my brotha!!!
#315280 KITCHENAID Side-by-side Refrigerator Model: KSRS27IHBL02
Posted by Applianceman97 on 12 March 2015 - 04:43 PM
Did you follow the correct harvest procedures? This requires cycling power to the unit I beleive.
#315241 RS263TDWP/XAA Samsung side by side not cooling well
Posted by Applianceman97 on 11 March 2015 - 09:44 PM
Rbm is right. Most fan related issues with Samsungs is caused by a plugged condensate drain.
If haven't read this before, it's worth a read! Great blog from brother Durham about Samsung refrigerator repairs.
http://appliantology...supremacy-pt-1/
#315205 Whirlpool DW DU927GWDB1
Posted by Applianceman97 on 11 March 2015 - 01:36 PM
Moved to manual request.
#315119 Kenmore Washer 110.45981 400 (elite he4t) manual request
Posted by Applianceman97 on 09 March 2015 - 08:53 PM
There are tons of manuals for the duet in the downloads section. You can use appliancepartspros cross reference tool to cross the main control part number to a whirlpool model number. Then search the downloads for that whirlpool number.
#315114 W/P wtw4950 No Spin
Posted by Applianceman97 on 09 March 2015 - 08:37 PM
Usually when these caps go bad they melt down. At least the ones I saw were. I have seen a few intermittent shifter/Optic sensor faults. Also check to make sure the drive block is in good condition. I'm gonna put my money on the shifter though. Keep us posted.
#315113 Admiral Dryer ADE7005AYW Will Not Turn
Posted by Applianceman97 on 09 March 2015 - 08:34 PM
Is the belt burned up/cracked right at the motor pulley? Can you give it a little help to start turning and then have it run?
Sounds like a belt issue if the drum will turn freely by hand.
