aehrhar2
Member Since 21 Mar 2013
Offline Last Active Apr 01 2013 07:57 PM
In Topic: Bosch 3200UC troubles
31 March 2013 - 10:29 PM
I ordered a used one and no I did not test the supply voltage.
31 March 2013 - 08:17 PM
I ended up ordering a new drain pump because it had a reading of 15.8 ohm's and it calls for 140-200. I received a used pump mad it has around the same reading, either this part is bad too or I'm taking my measurement wrong. I am testing on 1&2 connections on the drain pump with meter set to ohms. Any suggestions would be appreciated.
22 March 2013 - 10:15 AM
Is the filter by the pump on the lower right hand side?  or do you have to take the front off in order to access it?  Is the filter inside one of the hoses connected to the pump?  This could be a possibility because I found alot of mold when i drained and cleaned the pump, but i have not removed everything yet.  Going to do that this weekend.
