aehrhar2
Member Since 21 Mar 2013
Offline Last Active Apr 01 2013 07:57 PM
Bosch 3200UC troubles
21 March 2013 - 01:47 PM
Hello all, my problem is with a Bosch WFMC 3200UC washer.  I cannot get the washer to drain and I have cleaned and checked the pump and drain hose for blockage.  The pump will run if I have the drain cover off without water in the machine.  Although, if I start a cycle and switch it to either the spin or drain cycle it will do nothing.  The pump will not kick on and I cannot get the drum to spin.  The drum will spin in the wash cycle to agitate the load but nothing high speed.  Any suggestions/ideas? Thank you.
