brm
Member Since 27 Mar 2013
Offline Last Active May 02 2015 02:02 PM
In Topic: GE stacked washer gtun275em1ww i don't have ser @ this time
30 April 2015 - 06:39 PM
thank you
In Topic: GE fridge # PWE23KMDDES, SER #TD508201
15 April 2015 - 05:09 PM
I found the proper service manual. GE 2014 French Door Bottom Freezer With Internal Water Dispenser TB10-14 pg6 has how to get into Diagnostics & *If unable to enter Service Mode, use Service Diagnostic Kit WX05X10029. hope I never need the kit, expensive $150.00 for kit. thanks for yore help
15 April 2015 - 04:39 PM
PUB 31-51845-1 its on pg1 Service Diagnostic Functions, and says Non-dispenser needs service kit. but dos not say what the kit is.
14 April 2015 - 04:02 PM
in the service diagnostics info, I found one line in manual that I mist yesterday. (Nondispenser models require use of a service kit.) Does anyone know what service kit there talking about?
13 April 2015 - 03:15 PM
I went back out today. The model number calls the fridge out to be a Profile model, but it looks like a Monogram model. This refrigerator does not have an icemaker or water dispenser in the door.
To put it into service diagnostics I would need a different set of instructions. It calls out to push "water crushed and cubed " keys together (these keys are non-existent). This machine has a control on the inside edge of the left door. (see photo supplied)
I found the tech sheet in the machine, there were two: #31-51895 and #31-51901. These sheets call out the same service diagnostic instruction. I did guess at a number of key combinations, but none were successful.   thank you
side note}
fist time out (outlet is grd & ck's good) I had told her to get a surge protector at 1000 jewels, she did & unit has not shut off for 3 days. prior to this she had to unplug & replug it in 5 times a day to turn all back on. Id still like to run a diagnostics if proper key codes are available.
