brm
Member Since 27 Mar 2013
Offline Last Active Yesterday, 06:48 PM
2012 Frigidaire Fridge mod. FFHS2622MSB ser. 4a24623594
19 March 2015 - 04:57 PM
using clamp-on ammeter and an IR temperature gun fridge test is new info to me I will add this to my routine of tests before I call it a fault in the system.  Of course, I will have to work with it awhile to be assured I am using  this new information correctly. For example, today I was on a 2012 Frigidaire Fridge mod. FFHS2622MSB ser. 4a24623594;  fridge at 45° (damper good, fans good) she has both thermostats all the way up, food is frozen in freezer. The evaporator coil is not fully frosted reading at +15 to +45, so I called it a system fault.
 I did not leave without taking a temp reading of the condenser. It was exactly 100 °.  The compressor  is running  normal.  No ammeter test, it was in the truck. So, with this new info, if I got it right,  it tells me the condenser temp is good, therefore, the presser is good. Then no blockage or loss of Freon. I must actually need a control part  #241739712 ?
capital range model gscr484qgnat serial gcr484qgnat service manual
27 February 2015 - 03:54 PM
the blower fan in rear near top of unit stays on continuously. dos anyone have a service manual & a parts brake down for this one? thank you
GE Bottom-Mount french door Refrigerator # GFE28HMHCES ser# td529369
09 February 2015 - 05:43 PM
Service Manual Request  thank you
gas kitchenaid cooktop mod# KGCT305BAL0 ser# xg4101046
30 January 2015 - 06:20 PM
Service Manual Request for a 4 burner gas  kitchenaid cooktop mod# KGCT305BAL0 ser# xg4101046. im having a hard time figuring out how to open the unit up i have tried using the 5 burner MODEL KGCT366E service manual #4317225 butt they are not same. thank you
Kenmore Electric Range 79095412104 Service Manual
11 December 2014 - 07:32 PM
thank you
