LI-NY Tech
Member Since 30 Mar 2013
Offline Last Active Yesterday, 08:13 PM
In Topic: Dryer heats with no drum - with drum; no heat
Yesterday, 06:41 PM
Maybe a bad centrifugal switch on the motor which only manifests when there is tension on the motor pulley...
In Topic: GE refrigerator PSI23NGMABB - frozen auger motor
26 August 2015 - 05:07 PM
Found a bad evap motor (intermittent), replaced it, problem solved.
In Topic: Viking Refrigerator VCSB5481C(D) - No Water to Dispenser
23 August 2015 - 11:35 AM
This model uses a primary single solenoid and a secondary dual solenoid valve...are both working?
A common place for the water line to freeze is the point where it runs directly under the freezer. If you follow the line from the secondary valve over to the left you will see it runs up into a passageway under the freezer and then to the door. It may br frozen there.
If you're getting water out of the secondary valve you know both valves are good and the line is likely frozen.
In Topic: GE Profile Refrigerator - Inverter Problem - No Cool
17 August 2015 - 04:47 PM
It's available here for $346 US.
Part number: AP5796378
In Topic: Viking refrigerator model vcsb42355
16 August 2015 - 01:46 PM
Ok good. That's just a test mode though. There may still be a problem. Give it 24 hours.
