LI-NY Tech
Member Since 30 Mar 2013
Offline Last Active Yesterday, 01:08 PM
Frigidaire FGHB2869LF3 - icemaker evap drain leak
09 October 2014 - 06:20 AM
Monday I worked on a  french door Frigidaire FGHB2869LF3 with the fresh food section icemaker.  The complaint was fresh food section not cooling.  What I found was ice in the  bottom of the fresh food section and in the air ducts, down into the freezer around the evap.  I found a trickle of water coming down from the fresh food icemaker evap drain.  The drain cover was not sitting flush against the wall and so water was dripping out.  The drain is not clogged.
I got the cover to sit flush and I was able to stop the water from trickling out.  Defrosted the ice.
Today she called back, water under the fresh food drawers again.  I'm going back this morning.
Any ideas?  Am I missing something?
New Appliance Service Manual added: MSA Training Tech Bundle - Summer 2014
19 September 2014 - 04:17 PM
File Name: MSA Training Tech Bundle - Summer 2014
File Submitter: LI-NY Tech
File Submitted: 18 Sep 2014
File Category: Appliance Repair Manual Pot Luck Supper
1. MSA Electrolux DW Training:
EDW2455
EDW2491
EDW4905
EDW5905
EDW5305
EDW6405
EDW6505
2. MSA Whirlpool Kitchen Aid Dual Evaporator Refrigertor Training
3. MSA Whirlpool Maytag VMW Training 2
MVWC400
MVWX500
MVWX550
MVWX600
MVWX700
WTW4950
WTW5500
WTW5600
WTW5700
4. Whirlpool Kitchen Aid Maytag Dual Evap Ref Job Aid W10444924
KFIS29BB
MFT2976
WRFIS29
WRF759
WR59S
WRF789
WRF989
WRF990
Click here to download this file
GE oven JTP56SD1SS. F0/F7
26 August 2014 - 06:25 AM
GE oven JTP56SD1SS.
Approx one month ago a customer was experiencing F0 and F7.  As per mini manual, I disconnected ribbon cable, and the fault code still occurred, so I replaced the control.  Now, about 2 weeks later, customer calls back with the same complaint (before replacing the control F0/F7 came up multiple times per day, this time it was good until today).
Is this a keypad issue now, or a defective control, or something else entirely? How is it possible to set the code with the ribbon cable disconnected if there is no problem with the control?
New Appliance Service Manual added: Whirlpool ED2FHGXSQ00 Refrigerator Wiring Sheet
20 August 2014 - 10:10 AM
File Name: Whirlpool ED2FHGXSQ00 Refrigerator Wiring Sheet
File Submitted: 20 Aug 2014
PUB 2255377
ED2FHGXSQ00
Baseboard Maid O Mist auto vent replacement
14 August 2014 - 06:30 AM
I'm remodeling my kitchen and in the attic above the kitchen, on the baseboard pipes (which run through the attic to the bedrooms) is a Maid-O-Mist No. 66 Auto Vent (see images below, linked to Dropbox). It is clearly in need of replacement and I'd like to replace it now that I have easy access.  I think it's on the supply line, it's on the pipe that runs off the circulation pump.
The boiler has it's own pressure relief valve (and the boiler will be replaced this spring).
My question is is this the correct placement of this vent and is this the correct type of vent? Just about everything in this house was done incorrectly so I thought I'd check on this before I just swap it out.
Should I move it to a more accessible loaction? This loaction will be very difficult to access once the ceiling is back up.
And is there any thing I need to do with this vent once it's replaced (I'm also replacing a section of baseboard in this zone) such as purge air?  Or does it do this automatically?
Thanks
