philcheck
Member Since 09 Apr 2013
Offline Last Active Jan 22 2015 04:05 PM
In Topic: Fischer&Paykel DD603 not fully draining
05 December 2013 - 01:07 PM
no double drawer models for this puppy...!
In Topic: GE GSS201EPA SERVICE MANUAL NEEDED
25 July 2013 - 09:56 PM
THATS GOT TO BE IT....THE WORDING ON THE SHEET LEADS YOU TO BELIEVE THAT IT APPLIES ONLY TO "ALL BOTTOM FREEZER MODELS..WITH ENCODER MODELS WITH THE FOLLOWING SERIAL NUMBERS  ETC ETC ETC"  WHEN IN FACT ITS "ALL BOTTOM FREEZER MODELS  AND ALL OTHER ENCODERS MODELS WITH THE FOLLOWING SERIAL NUMBER"    UGH...DRIVES ME CRAZY!!! :woot:  :wacko:  :pint1:
25 July 2013 - 09:42 PM
LF2     YOU MEAN I HAVE TO READ THE INSTRUCTIONS?   :woot:
In Topic: Whirlpool IDI Ice Maker/ W10122502 cheap sub?
07 May 2013 - 09:34 AM
I noticed the fill valve that is used with this model ice maker says 65cc on a sticker on the top of the coil..we measured the mold volume of water and the new w10300023 takes approx 1/4 cup of water, where the old style mold takes almost 3/4 cup...I wounder if you must use the 65cc fill valve with this smaller mold? it looks like the control module is different also its blue in color..anybody else run into this new beast?
