ARAGON77
Member Since 10 Apr 2013
Offline Last Active Apr 18 2014 12:48 AM
In Topic: Taking the freezer door off GFSS6KEXASS
14 January 2014 - 03:00 PM
Have you tried removing the the freezer lower basket ? Some bottom freezer doors have screws on the out side of the rails by the door .
In Topic: Frigidaire GLTF1670AS0 doesnt drain and spin
13 September 2013 - 07:57 PM
ok  some frigidaire front load washers  , have a load balance sensor .  check your load . also try the spin cycle with  just a couple of wet towels ,
In Topic: G.e dryer won't start
13 September 2013 - 07:35 PM
first I want to thank all you guys for your respond to this matter .
ok  i went back to trouble shoot this dryer . and I noticed   the  drum lamp is not turning on when dryer door opens ,
next i checked the door switch and switch is ok .
also i checked the ( DEADMAN ) switch  idlerswitch -belt switch  and  its also good ..
 i checked for voltage coming out from the power board to the dryer motor but im not getting anything .
i dont want to blame the power board ( control board )  but so far it is the only suspect .
Does any body have any other tips on how to troubleshoot this dryer ?
 I dont want to turn my self in to a changing parts monkey !!!!!!!!
In Topic: A.O. SMITH PROMAX WATER HEATER MOD - FCV 40 100 nat . Gas
16 April 2013 - 01:48 PM
A big thanks to all for these useful tips , I'm going to try cleaning this lint ,oil screen and hopefully this will solve this problem . Once again thank you all for your help
15 April 2013 - 08:57 PM
The pilot and the burner will shut off at the same time , pilot and burner only stay on for about 25 minutes .
And no there is no sediment. Trap at the gas valve inlet . I just put in a brand new thermocouple
