tuc
Member Since 14 Apr 2013
Offline Last Active May 27 2013 10:15 AM
#255812 maytag dishwasher mdb7759 won't start
Posted by tuc on 24 May 2013 - 04:01 PM
thanks for your reply, sorry it took so long to get back to this.
 I think it was a lock problem, I read a similar problem on a different make/model that suggested that and told my friend to try unlocking it . he was able to get it working.
thanks for your advice CHAT_IN_FL
#252623 LG DLE 5977B NO HEAT
Posted by tuc on 18 April 2013 - 06:39 PM
just wanted to update
while installing the new thermal fuse I also replaced the high limit thermostat in the heater housing and the thermistor in the blower housing. even though they checked good, they were cheap to replace while I was in there.
doing the suggested checks, everything seem to check good
no heat while in the fluff cycle
heat turned off when door open
output temp at vent with empty load on high heat  150-170, med heat 132-155, lowest heat 105-118
ran dryer for 20 min on high heat without blowing thermal fuse.
plan to install dryer this weekend, and will redo vent for little or no flex, and hopefully no way they can kink it.
thanks regus and john for your patience and help
