HVAC TECH
Member Since 17 Apr 2013
Offline Last Active Jun 03 2013 01:50 AM
In Topic: Frigidaire Washer Drier Combo front loader
02 June 2013 - 08:18 PM
Ok I can do that. Got to go to dinner first but when I get back I'll start another load. Just post a link to the video on YouTube, right?
In Topic: Reversing Valve
02 June 2013 - 08:13 PM
It sounds like you got it running and that's great but from my experience if it happened once it will happen again. The reversing valve should not get stuck in the middle of the valve during normal operation. This is one of the leading causes of compressor failure on heatpumps. If the compressor was damaged while the system was running with the reversing valve stuck in the middle of the valve make sure that a new reversing valve is installed with the new compressor.
02 June 2013 - 07:32 PM
Ok, I would first like to thank the people that contribute and the creator of this site. The help provided was accurate and prompt. I've been operating my washer and dryer for a month now and noticed that during the first rinse cycle the washer will start to drain and fill while slowly spinning. That part is great but the tub will start to spin at a certain rpm, which isn't to fast, and the tub will hit the sides of the dryer a couple times and then it will stop and start to the next rinse cycle. This only occurs on the first rinse as the washer only spins at this rpm for about 5 to 10 seconds. All the other rinse cycles spin at different rpm's and there is no banging. I don't feel that this is normal. Any help would be great.
22 April 2013 - 10:58 PM
I was looking at the parts that were available and ran across this
Item #936915 (OEM Part)
MFR #134146100 which it states that it is a seal that goes between the two outer tubs. I did not see one when I separated the outer tub. Is this seal needed? It looks like it may be #21 on the diagram above.
19 April 2013 - 12:27 PM
Thanks for the help. I've got the inner drum on order.
