JJ Surfer
Member Since 21 Apr 2013
Offline Last Active Oct 06 2014 10:45 AM
In Topic: Kenmore11077656100 wont heat
06 October 2014 - 10:45 AM
The problem is the gas valve, I agree with Fairbanks and order the burner assembly, you should many years of trouble free heating
In Topic: MAH5500BWW motor/motor control kit: need help
06 October 2014 - 10:31 AM
Should work fine. The one connector that won't match has the black , white and ground in it. I've modified that connector so that there is a secure connection of black to black, white to white etc. that goes into the filter, there is a connector included to connect to main mcu. If any other connectors are different, check back
In Topic: #253.55679407 no power to compresor after replacing ADC
01 October 2014 - 07:08 AM
The damper opening and closing could be a a bad damper or controller but it really doesn't matter because you also have a sealed system problem. Most likely a leak but it could be restricted or a bad compressor in any case the fix at this point is a new refrigerator.
In Topic: G E gas cooktop model JGP326WEV1WW
01 October 2014 - 06:56 AM
Sounds like leak detector might have caused this. Try unplugging each burner switch one at a time and see if clicking stops. If the clicking persists it would be the spark module but I'm betting its a burner switch that got a little wet.
In Topic: Kenmore 795.71023.010 Compressor not running
01 October 2014 - 06:43 AM
The unit will not go into defrost 33 if the evap is not cold. I agree with Ivasquez..sealed system leak
