Thirstytech
Member Since 22 Apr 2013
Offline Last Active Yesterday, 04:05 PM
#320910 K-Aid undercounter IM -- KUIS18PNXB0 -- does everything too fast
Posted by Thirstytech on Yesterday, 07:42 AM
Tech line always says "don't replace the board" it's their mantra. I have seen crusty connections for the pump but they always resulted in the pump not running.
Replace the board.
#320782 Superba Ice Dispenser frosting up -- KSRB22QFBL00
Posted by Thirstytech on 26 May 2015 - 03:42 PM
Shine a flashlight by the flapper and see if any gaps are present. A common thing is to have broken/cracked mounting tabs on the door which will cause the flapper to be all loose. They make this kit for that condition: Part number: ap3872692
#320437 The lady of the house asks" Do you have protection?"
Posted by Thirstytech on 20 May 2015 - 03:56 PM
You can usually tell right when you pull in the driveway if your'e going to be "booting up" for the call.
Kind of makes you appreciate laundry set ups like this one at a local farmers migrant camp, laugh all you want he pays cash every time!
#320048 Maytag french door refrigerator mod#mfx2571xem3
Posted by Thirstytech on 15 May 2015 - 03:49 PM
Witness and behold the power of the Samurai's video sword: http://appliantology...tor/?hl=freezer
#319204 JENN AIR OVEN DOOR NOT CLOSING PROPERLY MOD: JDS9860P
Posted by Thirstytech on 05 May 2015 - 08:07 AM
I think on these you have to remove the bottom kick plate to get to the mod/ser tag.
#318785 Jenn-Air JJW3830WS00 F8E1 Low Fan Speed Overspeed
Posted by Thirstytech on 29 April 2015 - 08:01 AM
A $1000 UI ??!!!!!!  That'll build customer loyalty......... :no:
#318783 Kitchenaid Side x Side Refrigerator KSRP22FNSS00 No Ice
Posted by Thirstytech on 29 April 2015 - 07:56 AM
Did the new I/M cycle and fill when you jumped it out (T & H)?
#318539 Kitchenaid Bottom Mount Kfis29pbms00
Posted by Thirstytech on 24 April 2015 - 07:51 AM
By your statement it does sound like you could have a main control problem. You will only be able to confirm by checking your input and output voltages on the control fir the components not working correctly.
Tough love - but still love. Sage advice.
#318186 Whirlpool LSQ9549pw2 drip drip drip into tub when not in use...
Posted by Thirstytech on 19 April 2015 - 10:09 PM
If it continues to leak with the unit unplugged, replace the water inlet valve.
#317933 Vibrations in the freezer, 10672206201
Posted by Thirstytech on 16 April 2015 - 08:10 AM
It may be the motor but, I've encountered a few of these where the fan blade seems to walk back on the motor shaft to the point where the back of the fan blade makes contact with the motor causing the noise.
The fix has been to pull off the fan blade and put a small spacer (usually a copper ferule) on the motor shaft between the blade and motor.
#317930 MVWC6ESWW0 maytag washer filling and agitating at the same time.
Posted by Thirstytech on 16 April 2015 - 08:01 AM
Ahhhhh..... the smell of easy money!
#317756 Kitchenaid ice machine Kuic18nnxs
Posted by Thirstytech on 14 April 2015 - 12:19 PM
A beginning, middle, and happy ending - my kind of story!
#317755 Kitchenaid Kssc48qms01 thawing overnight
Posted by Thirstytech on 14 April 2015 - 12:17 PM
Here is what the flashing LED means on the inverter:
http://appliantology...nverter-boards/
Thank you Bruther Strathy! This nugget is now safely stored in iBooks for future troubleshooting adventures.
#317512 Kitchenaid Kssc48qms01 thawing overnight
Posted by Thirstytech on 10 April 2015 - 11:48 AM
Will it go into diagnostic mode?
I recall working on one of these that would very intermittently stop cooling. It would not go into diagnostic mode, or more accurately it would not go all the way through diagnostics. it ended up being the infamous control board.
Part number: ap4411082
#317511 Kitchenaid ice machine Kuic18nnxs
Posted by Thirstytech on 10 April 2015 - 11:42 AM
Put your amp clamp on one of the compressor leads and let us know what it's drawing, please.
