tjcin
Member Since 24 Apr 2013
Offline Last Active Nov 06 2014 05:25 AM
In Topic: Whirlpool Duet Sport Washer
09 May 2013 - 06:17 PM
The problem was in fact the MCU.  I don't know or really care if the CCU and door lock were bad in addition to the MCU, but the replacement of the MCU cured it. The Duet Sport is, for now, back in action.  Thanks everybody for all your input.  Tim C
06 May 2013 - 05:33 PM
Would a bad MCU prevent the machine from turning off from the soft touch button?
04 May 2013 - 07:04 AM
I did not replace the pressure hose.  I did a visual inspection of the hose and didnt see any wear or cracks.  And yes, all the panels are on the machine and no switches are bypassed.  The F28 was one of the three original codes the machine threw when it initially stopped working.Back to the pressure hose.  Would a bad hose cause it to just sit and do nothing after the door locks?  I also just found another symptom.  After the power cord is plugged in and I hit the power button on control panel the machine turns on.  But when I hit the power button again to turn the machine off it doesnt turn off.  It has to be unplugged.  Thanks for any help.
03 May 2013 - 04:46 PM
OK, I have thrown some parts at the machine.  I bought a new FSP CCU and door switch.  This cleared the F20 and F24 codes when in diagnostic mode but F28 still exists.  The door now locks but the machine won't start a wash cycle.  Do I buy a motor control board or is it time to buy a new LG?  I could really use some help, thanks.  Tim C
26 April 2013 - 03:33 PM
Thanks for the input.
