Spannerwrench
Member Since 25 Apr 2013
Offline Last Active Today, 08:51 AM
In Topic: Bosch SHX46A05UC/30 does not enter cycles
Today, 08:52 AM
Go from the to buttons you select cancel/drain the first is A, then B. then C.  If the Delicate light is C it is a heating error.
In Topic: GE ziss420drkss inverter board
Yesterday, 10:47 AM
Even though I almost always order through Marcone, I always research parts on the manufacturers IPL database before I order it through a parts distributer.  I've never had a problem with the GE IPL.
Yesterday, 09:07 AM
According to GE Parts database it takes WR55X10685 which crosses over to
Part number: WR49X10283
And APP also says it's compatible with that model.
In Topic: Kitchenaid KSCS25INSS00 compressor cooling fan not working
24 April 2015 - 01:16 PM
It listed in the parts break down under the unit parts
That doesn't mean it's the one that controls the unit, the 'Unit Parts' means that the parts listed are in the compressor compartment generally.
You need the Electronic Control which is no longer available and must be sent to get rebuilt.
Part number: AP4411082
In Topic: LE error code on LG WM2487HWM - Main board failure?
23 April 2015 - 02:56 PM
Listen to me now, believe me later and hear me next week:
DO NOT USE CONDUCTIVE GREASE!
The only grease you should ever use is SILICON DIELECTRIC GREASE.
End of Line.
I tried hitting the like button on this one to get more like but all it did was unlike and re-like!
All of my service vans carry DiElectric Silicon Grease to use on any refrigerator connector or any low voltage connection that they make.  This may be overkill but I think it's a good security measure over the long term.  I order the Frigidaire grease because I don't know of any other manufacturer that sells it as a part number.
Part number: 5304485963
Dielectric grease is also considered synthetic grease.
