Spannerwrench
Member Since 25 Apr 2013
Offline Last Active Yesterday, 07:01 PM
#314622 Thermador Dishwasher DWHD640JRR/50
Posted by Spannerwrench on Yesterday, 03:49 PM
You're bound to find what you need here.
Just make sure you have the exact Model Number to get the right product.
http://appliantology...-manual-bundle/
#314597 Thermador Cooktop service manual sgsx365zb
Posted by Spannerwrench on Yesterday, 12:53 PM
Repair instructions (ARA)  and Schematic: http://appliantology...and-schematic/
#314593 Thermador Downdraft Wiring diagram cvs36rb
Posted by Spannerwrench on Yesterday, 11:20 AM
Here brother
http://appliantology...vent-schematic/
#314428 GE Profile Refrigerator model PFSF6PKWBWW
Posted by Spannerwrench on 01 March 2015 - 12:41 PM
Just an FYI.
Some of the tubes didn't have the additional holes, the kit part number I mentioned comes with the new style drain tube.
#314418 GE Profile Refrigerator model PFSF6PKWBWW
Posted by Spannerwrench on 01 March 2015 - 11:55 AM
I agree with both of you in many ways, I don't understand why the need for an evaporator being replaced, and as Bryan stated, probably inexperience on the techs part (lack of proper info and/or training).
The first I heard of moving the thermistor to the center was from the ASTI notes.
Here's my notes from Evernote on this challenge. As a side note here's a few other Samsung tips I've learned recently.
***Order Kit  Part number: DA82-01415A
 & Defrost Heater Clip Part number: DA61-06796A
 Use this clip instead of the one in the kit.***
***You must replace any damaged fresh food evaporator cover because a damaged cover or damaged styrofoam WILL cause a future frost problem.***
Caution:  On newer models: Bad overload will kill power to the entire unit.
                The Ambient Sensor will stop the condenser fan from running if lower than 68 degrees, even in diagnostic mode.  Exe; AC vent pointed at the upper hinge.
#314368 Asko T712 dryer heater always on
Posted by Spannerwrench on 28 February 2015 - 01:42 PM
Actually it looks like this is a dual element, one gets voltage all the time and the other is switched by a thermostat.
Attached File  asko.png   20.68KB   0 downloads
As you can see, the German and Swedish wiring diagrams suck.
Here's the complete diagram if anyone is interested.
https://www.dropbox....000866.pdf?dl=0
#314367 Asko T712 dryer heater always on
Posted by Spannerwrench on 28 February 2015 - 01:33 PM
I haven't looked at the wiring diagram for this unit yet but, most likely 120v goes to the heater though the Power switch and the Control supply the other 120v.  So with a shorted element the element would heat at a lower heat output because the ground would be providing a neutral path.
Again I haven't looked up the wiring diagram yet.
#313994 Uline ULN-BI95BTP-03 start relay
Posted by Spannerwrench on 23 February 2015 - 05:33 PM
5419
Part number: ap3841433
#313786 bosch SHY66C02UC/14 - diagnostic challenge - is it the control board?
Posted by Spannerwrench on 19 February 2015 - 08:26 PM
Sounds like a bad control as mentioned, use the first method you mentioned to enter diagnostics and let it run while measuring current draw.  Report back the information.
#313699 Kenmore refrigerator 106.8536780 garage kit available?
Posted by Spannerwrench on 18 February 2015 - 05:25 PM
The kit is for him or her to buy a Gladiator :) I only know of Frigidaire having any kind of kit like that.
The only reason that Frigidaire has a kit, for both a hot and cold garage, is because they sell such cheap x-top units that everyone thinks they can use it for a garage refrigerator.  They still don't guarantee the unit if it's installed in a garage and the kits are only sold as accessories.
#313683 Kenmore refrigerator 106.8536780 garage kit available?
Posted by Spannerwrench on 18 February 2015 - 03:12 PM
No kit for this one.
#313520 Thermador SCD272TW/01 Upper oven heats up slowly
Posted by Spannerwrench on 16 February 2015 - 02:03 PM
What do you mean it looks like it's getting full voltage, unless there's some magic method to sing voltage, then the only way is to put a meter on it and check.  Either it's not getting full voltage or the element is becoming weak.
#313493 DCS cooktop explodes
Posted by Spannerwrench on 16 February 2015 - 06:06 AM
DCS uses a small separate orifice for the simmer, I've seen them partially clogged causing this to happen.
#313372 Samsung Electric Range Model # NE58F9710WS
Posted by Spannerwrench on 14 February 2015 - 05:25 PM
Model:
NE58F9**  Fast Track
 Publication # DrNE58F9 Production date :6/24/13
and
Training Manual
#313371 Ge Dw not drying dishes 2012
Posted by Spannerwrench on 14 February 2015 - 05:02 PM
Here's a link to the service pointer that was mentioned for the kit that the Wolf mentioned above.  I didn't respond earlier because I didn't see a model number, and I don't look at the tags.
http://appliantology...sh-performance/
