curjones
Member Since 26 Apr 2013
Offline Last Active Aug 10 2015 09:16 AM
LGUB2642LF2 Frigidaire condeser fan
31 July 2015 - 06:55 PM
Replaced the inverter.. condenser fan not running..tec sheet does not give voltages.
Fan rated For 120. Volts
But is it getting a variable Hz from board.
I got a 26 volt signal at connector to fan.
At main board.. J'2 red to a lt blue .netural I did not get 120.. vac
What is the out put signal from main board.
They referred to the fan as a CCV condenser motor.. want to verify if that means.. it will be getting a varible signal (Variable capacitance. ..conuctive???)
Ive searched the net..
Thanks for your help
Kenmore (Midea) 255.197020107 freezer
10 March 2015 - 02:10 AM
Oh what fun finding PTC relY.
Under the model number most places for parts dont have them availiable.
I have found some but they are pricey.
This is information and also questions.
The orginal part has BQP2-4.7 Ty
has a round disc type overload
This unit has a run capacitor so requires a 3 pin relay.
I found a CB65A-1 looks just like the one I took off.
A. Not sure of ohm specs
B. Wonder if its a cheap piece of Chinese crap like the orginal.
C. Pricey
The second suggested parts I found was a 6R8md3 relay and a 314mFBYY overload.
Again not sure of specs.. but relay appears to have the right configuration and it says it is a PTC
WAS recommended for a magic chef small freezer.
I also was looking at a Whirlpool 4387913 which has a relay and overload.
Question is:is this relay a PTC or inductive type?
These are a reasonable price.
I know the overload has to be sized right and if I were in the parts business I might have a cross refrence guied.. Im still trying to figure out the codes on them.
I see the easiest solution as; going with the CB65A-1. but does anyone suggest or know of a higher quality part solution?
Thanks.
maytag washer MAV5057AWW
07 March 2015 - 03:09 PM
Will replacing the suspension spirngs stop the unit from walking out of spot.. when unbalanced load is in it.
The unit does great but if not attended it will take a trip.
Will new springs help or is this just a trait/charastic of these older maytags.. thanks
trouble with download
02 February 2015 - 11:08 PM
Im trying to down load manual for wf448aapxaa. Samsung fl washer. Working with my phone.. not letting me admin error coming up.. thanks.
samsung front load washer WF448AAP/XAA02
02 February 2015 - 10:52 PM
Drum is off center. FIGURE the back support with shaft is cracked. Found that part but bearning are not available. . Amazon poped up a 5300137158 kit.. has any one been doing them with success.. need the right bearing number.
