ncsu95
Member Since 01 May 2013
Offline Last Active May 08 2013 02:19 PM
In Topic: Samsung Fridge RF267ABPN Defrost Issue
07 May 2013 - 03:33 PM
Went ahead and bought the whirlpool heat strap. That makes a lot I sense as to why the drain hole freezes over.
Thanks for all of the help!
06 May 2013 - 07:17 PM
Yeah I noticed that but every other site calls it the defrost sensor.
Thanks for replying.
06 May 2013 - 06:31 PM
Anybody?
04 May 2013 - 05:15 PM
Ok I went ahead and used the hair dryer and hot water. This cleared the drain. I poured some water into the drain and it went down the tube and into the defrost tray at the bottom of the unit. By the way, the tube on the right is the one for the fridge.
I then ran a manual defrost and it defrosted properly so I am assuming the problem is the sensor. Looking at the manual I believe the sensor part # is DA32-00027B. Would someone please confirm that this is indeed the correct part # so I can go ahead and order it?
Any other suggestions?
Thanks!
03 May 2013 - 07:28 PM
Having a hard time get the post right!
