okiepiper
Member Since 08 May 2013
Offline Last Active May 25 2013 01:58 AM
In Topic: Bosch WTA3510 dryer won't start
23 May 2013 - 04:28 PM
I'm not worthy....  I'm not worthy!!!  But, very cool - thank you!!!  :rocker:
Sho nuff good to know, buddy-row!  For your contribution to the borg-like wisdom that is Appliantology, you have earned a free six month extension to your Apprenticeship.
Kanpai!   :samurai:
23 May 2013 - 04:23 PM
Yup - that's the perpetrator! I plugged it in and the dryer fired up w/o problem!
You mean this thing was causing all the problems?  http://www.repaircli...lNumber=WTA3510
23 May 2013 - 03:19 PM
Resolution....  Door contact switch was the problem!  Advice from the novice - don't be fooled by the timer countdown or the little blinking dot in the timer window.  Somehow, the part can fail in such a way that the dryer won't turn, but some of the electronics thinks it's OK.  Lesson learned! :tongue:
PS  Thanks again for all the help folks - it is truly appreciated!!!
17 May 2013 - 09:11 PM
Ran diagnostics again for confirmation - identical responses with both the new and old boards = no drum rotation and no heat.  R3 (dryer door) ~ 16k, R2 (heater) ~27k - dryer is in the cool garage, so I'm not that surprised that the resistance is higher than the spec.  Can't find R4 on the schematics...  One thing I did notice is that if I rotate the auto-cycle knob to damp dry, the number 16 appears on the display.  Can't find any reference to "damp dry" being a test, so I don't know what I have in that number...  Beer:30...
17 May 2013 - 05:59 PM
Thanks PDuff!  I will check resistances tonight... I already tried the red button - no clicky there, but I will give the thermistors/thermocouples another look... :thanks:
