okiepiper
Member Since 08 May 2013
Offline Last Active May 25 2013 01:58 AM
#255716 Bosch WTA3510 dryer won't start
Posted by okiepiper on 23 May 2013 - 04:23 PM
Yup - that's the perpetrator! I plugged it in and the dryer fired up w/o problem!
You mean this thing was causing all the problems?  http://www.repaircli...lNumber=WTA3510
#255709 Bosch WTA3510 dryer won't start
Posted by okiepiper on 23 May 2013 - 03:19 PM
Resolution....  Door contact switch was the problem!  Advice from the novice - don't be fooled by the timer countdown or the little blinking dot in the timer window.  Somehow, the part can fail in such a way that the dryer won't turn, but some of the electronics thinks it's OK.  Lesson learned! :tongue:
PS  Thanks again for all the help folks - it is truly appreciated!!!
#254373 Bosch WTA3510 dryer won't start
Posted by okiepiper on 10 May 2013 - 07:48 PM
I thank both of you now and in the morning!  Doumo arigatou gozaimasu!
You'll thank us in the morning.   :yes:
#254340 Bosch WTA3510 dryer won't start
Posted by okiepiper on 10 May 2013 - 11:33 AM
Just confirming my understanding - part below is power module, correct?  Not just some part on the PCB or somewhere else? I ask because ome sites call it power supply board and others call it a control module...  Consistency!
Thanks again!
http://www.repaircli...d/265677/467463
