drkwoods
Member Since 09 May 2013
Offline Last Active Apr 06 2015 02:13 PM
In Topic: Washer Dryer Combo Error Code ER13, Haier, Summit, Ariston
28 June 2013 - 12:18 PM
Finally Fixed!!  Swapped out the PCB WD-5210-12 and we have full cycles now.. Also pulled quite a bit of Lint stuck in the evaporation tank..   thanxx all for the help!
19 June 2013 - 02:49 PM
This thing has two PCB's I think...? Which one would I replace?  wd-5210-11   or    wd-5210-12 ?
25 May 2013 - 11:51 AM
It doesn't have an air/fluff mode. Not sure how to test heater for intermittant short?
25 May 2013 - 09:30 AM
yea the heater is fine.. nice and hot and runs the entire heat cycle until the error code at the 15min mark every single time
22 May 2013 - 07:53 AM
Well Ive tried everything and it all tests out ok. The thermostat, thermal link (fuseable) , the fan motor, the condensing tank (did have quite a bit of lint but not enough to stop drying), the Heater is fine..
I get ER13 code about 15 min into a dry cycle.. The wash cycles are all fine, no problem.  If I run the touch-up dry cycle it will error code in 15 min, I feel heat and there is decent fan and air flow, the clothes are even beginning to dry. Ive tried running the quick cycle again right after the Error code and it has made it through to complete a couple of times and didnt error or stop. So Im guessing I'll replace the pcb?  Can i test it? is there more than one?
