speeder
Member Since 12 May 2013
Offline Last Active Apr 28 2015 03:57 PM
In Topic: Bosch SHX 33A 05UC/21
12 May 2014 - 10:18 PM
ic. thanks.  of course, i should have known that the part that I need is not the more common less expensive one.
In Topic: has anyone taken apart a bosch dishwasher on/off switch and been able to put...
06 May 2014 - 07:47 PM
good rule.  will follow it next time for sure.
In Topic: Defrost problem - Viking VCBB363L
06 June 2013 - 11:45 AM
any solution to this problem?  having the same experience with a 5 year old fridge.  viking is *X*#*$*
In Topic: Viking Bottom freezer fridge - ice maker water valve replacement
15 May 2013 - 01:12 PM
So, from what I can tell from the service manual, V-N should show 500 to 1500 ohms resistance if operating correctly, and power off ie freezer door open.
V-N shows 0 ohms when freezer door is open (power off to ice maker)
Is there any way to check that power is being fed to the water valve through one of the probe points on the ice maker module?  I think if I short T-H to activate the ice maker, attach my multimeter probes to V and N, I should get 120V after I close the door, and the ice maker motor makes it around to the water valve activation portion.
thoughts?
Its very hard to get to the water valve.  I would prefer not to have to take everything apart only to find that the water valve is fine, and it's something else.
